Re: diesel fuel
Posted by old on March 29, 2007 at 17:30:15 from (4.245.6.196):
In Reply to: diesel fuel posted by Rodney E. Axford on March 29, 2007 at 17:05:08:
Fuel that old doesn't burn well and can gum up things also. I would drain the tank and the lines and change the filters you probably have a lot of water in very poor fuel and either one of both could well be your problem
