Re: Cant get H to run
Posted by El Toro on March 30, 2007 at 14:09:42 from (152.163.100.197):
In Reply to: Cant get H to run posted by eshoreboy on March 30, 2007 at 13:29:14:
Bring No1 piston to TDC on the compression stroke
and then take a look at the rotor and see which plug wire the rotor is pointing to. Are you getting any fire to the plugs? Pull the coil wire from the cap and hold it near a good ground
to see if you have fire here. You will need someone to crank over the engine. Take your ground wire off for the time being. Did you remove the mag from the engine? Hal
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
