H Oil Pump
Posted by Tom Windsor on March 30, 2007 at 16:47:27 from (69.40.61.69):
When I broke down the oil pump that came off this engine, I found a full tooth broken off the idler gear and 1/2 tooth broken off the drive gear. Having rejected that unit, I went through 2 more units until I got myself satisfied that the bearings were not worn out, turned freely and had all its teeth.
Having said that, I have thoroughly cleaned this unit up and ready to put it back together. MY QUESTION IS:
Is there anything inparticular that I should be paying attention to when I assemble this unit. I don't want to be taking this pan off again if there is something I can do ahead of time.
TW
