Re: 12 v conversion ballast resistor
Posted by Ron in Nebr on March 31, 2007 at 00:48:44 from (66.252.113.82):
In Reply to: 12 v conversion ballast resistor posted by Scott in Illinois on March 30, 2007 at 20:02:27:
Funny you should bring this up...just today I was working on a 12v conversion on a '50 Chevy truck, using Bob M's diagrams, and due to my memory being foggy, have a question...
If you replace the 6v coil with a 12v coil, do ya still need the resistor? I seem to remember most all 12v vehicles have a resistor, some are separate and some are built into the wire going to the coil. Do all 12v point type systems, regardless of coil voltage rating, only use 6volts at the coil?
