Re: 12 v conversion ballast resistor
Posted by El Toro on March 31, 2007 at 04:04:32 from (152.163.100.197):
In Reply to: 12 v conversion ballast resistor posted by Scott in Illinois on March 30, 2007 at 20:02:27:
You can eliminate the ballast restistor that your are currently using if you want to, by using NAPA's 12 volt coil with a built in resistor. The number of the coil is 1C14SB. Hal
