Re: Cant get H to run
Posted by El Toro on March 31, 2007 at 04:17:23 from (152.163.100.197):
In Reply to: Re: Cant get H to run posted by eshoreboy on March 30, 2007 at 20:14:32:
You need to bring that No1 piston to TDC on the compression stroke as I described earlier, then see where the rotor is pointing. Are you sure the
sparkplug wires are installed in the correct firing order? When you look at the mag's cap they should be in this order. This is very important.
2-1
4-3
Are you getting any fire at the sparkplugs? Pull one of the plug wire's off while someone try's to start the engine. The wires, rotor or cap can cause a no start. Hal
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
