Leaking Remote, 826
Posted by Jim Allen on March 31, 2007 at 04:56:35 from (209.173.160.22):
It's time for TRY THREE on getting one of my hydraulic control
valves (for the remotes) to stop leaking. It leaks out of the little
snapped in endcap, where you adjust the sensitivity. I have
replaced all the o-rings twice, the second time carefully
examining all the hard part for any problem. I see no abnormal
wear on anything, but I likely do not know what to look for. If
someone has some clues onthis, I'd be grateful to hear them. I
have the parts books so if you need to refer to parts, I can follow
along. The remotes work perfectly, but oil just drools out that
endcap... not a lot, but steady and the back of the tractor gets
NASTY with oil after a a coupla days working. Many thanks,
Gents!
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
