Re: Measuring RPM on M
Posted by Janicholson on March 31, 2007 at 06:14:55 from (66.216.226.55):
In Reply to: Measuring RPM on M posted by DenT on March 31, 2007 at 05:13:22:
four ways
Use a simple (some what old fashoned) Tach Dwell meter on the distributor primary wire (goes to the points)and ground. Reads rpm directly, cost about 20-30$.
Use a strobe shaft tach (probably rentable, or more expensive), but very useful for "no connection necessary" speed monitoring. They work on any moving mechanism or shaft.
Use a shaft tach on the belt pulley or PTO and do the math to determine engine speed. Still some fair cost, or rent.
JimN
