Re: Cub @ idle, part 2
Posted by gene (missouri) on March 31, 2007 at 14:19:29 from (64.85.215.198):
In Reply to: Cub @ idle, part 2 posted by Jesse on March 31, 2007 at 13:10:37:
Replace the coil with a known good one.
Double check your tune up. Did you retime the engine?
Whine from front of the engine. The hydraulic pump is located on the front left side of the engine. Low on hydraulic fluid?
The fan on older Cubs requires lubrication as well as the generator.
You need to locate the source of the whine. If the fan freezes up, it takes out the radiator.
Gene (Missouri)
