Re: Needing Help with H engine.
Posted by Dave S. on March 31, 2007 at 18:44:11 from (70.164.249.4):
In Reply to: Needing Help with H engine. posted by Tom Windsor on March 31, 2007 at 17:12:08:
Tom I had the same problem and had to make a new one for mine. I can't remember how long the pipe is but it came within 3/4 to a 1/2 inch of the pan, it is 1/8" pipe. It does not point straight down but points slightly forward. If you lay the pan on the engine and make the pipe so it has 1/2" to 3/4" clear above the pan it will work fine. It is the drain back to pan for filtered oil. I am in Sierra Vista AZ. and not at home in KS. or I would go find the old pipe and measure it for you. Dave
