Re: need your valued opinion on a 300 utility
Posted by gene bender on April 01, 2007 at 02:40:47 from (67.55.226.214):
In Reply to: need your valued opinion on a 300 utility posted by lekander883 on March 31, 2007 at 16:16:14:
You have to remember the tractor was never designed to haul 800lb bales around.If you use it to push snow and lift 300lbs it will serve you well and if you must lift heavier stuff get a newer rig and spend more money as you wouldnt take your 55 CHEVY pick-up and haul 1500lbs around verry long.
