Re: front loader
Posted by formerly ny bill on April 01, 2007 at 19:47:29 from (66.24.240.172):
In Reply to: front loader posted by Greg Hansen on April 01, 2007 at 15:24:20:
greg, i tried different cylinders on my new idea loader after the originals got bent. originals were about 3 1/2" OD and a 2" rod. new ones were about 5" OD with a 1 1/2" rod. new ones were sooo slow. i found some like the originals and replaced the 5" cyls. works fine now. years ago, dad had a loader on his 300 utility that had cylinders with a narrow bore with a larger rod so it didn't need to move so much oil to lift. could this be the problem on your 350?
