Re: Need the (Farmall) A Team! Cranking Issue...
Posted by El Toro on April 02, 2007 at 06:56:07 from (64.12.117.8):
In Reply to: Need the (Farmall) A Team! Cranking Issue... posted by dunniteowl on April 02, 2007 at 05:26:38:
Pull the sparkplugs and see if the engine will crank. You should be able to hand crank the engine and remove any water if there's any on top of the pistons. I wouldn't be pulling the tractor
since you can bend a rod or damage a gear. Hal
