Re: should my coil get hot?
Posted by old on April 02, 2007 at 13:51:15 from (4.244.6.40):
In Reply to: should my coil get hot? posted by RyaninKS on April 02, 2007 at 12:07:37:
Coils do get warm but not so hot you can't touch them. As Bob says if its 12 volts then you may need a ballast resister or you can also buy a 12 volt coil that doesn't need the resister which since it sounds like your coil is going bad I would go with
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
