Re: SC Crankshaft Pulley
Posted by Cedric on April 03, 2007 at 02:40:36 from (210.54.69.252):
In Reply to: SC Crankshaft Pulley posted by skycarp on April 02, 2007 at 19:12:23:
The end of the crankshaft is tapped ½" N.C. If you screw a piece of threaded rod into it long enough to pass through the pulley and a piece of heavy plate to cover the face of the pulley, and a nut, you can force it on by winding on the nut. That is the way I replaced the pulley on my Super C a few months ago. Warm the pulley up but nowhere near red heat. Sid.
