Re: A Carb troubles
Posted by Reddog on April 03, 2007 at 06:59:08 from (24.236.159.180):
In Reply to: A Carb troubles posted by Chad from Michigan on April 03, 2007 at 06:27:43:
Is the float good and more importantly is it set at the correct height ???? Is the air cleaner open and clear, does it have the proper amount of oil in the oil bath ????????
Just some random thoughts.
Mike
