Re: SC Crankshaft Pulley
Posted by El Toro on April 03, 2007 at 09:25:06 from (152.163.100.197):
In Reply to: SC Crankshaft Pulley posted by skycarp on April 02, 2007 at 19:12:23:
Heat the pulley in an oven to about 200 degrees, by the time you have it installed it won't be any hotter than the engine on a 90 degree day. Keep the bolts loose in the timing gear cover until you have the damper installed. Hal
