Re: A Carb troubles
Posted by Chad from Michigan on April 03, 2007 at 10:43:12 from (152.72.151.71):
In Reply to: Re: A Carb troubles posted by Wayne Swenson on April 03, 2007 at 10:09:34:
Wayne what size wire??? when you say clean out with the wire I tried this but the wire always dead ends. Are you pushing the wire clean through and then pulling it through? If you are doing this I am way in trouble or the wire I was using was to stiff and I could not push it through and around the passeges.
Chad
