Re: 826 is a money pit!!
Posted by Owen Aaland on April 03, 2007 at 20:56:21 from (65.165.246.79):
In Reply to: 826 is a money pit!! posted by Johnny Hu on April 03, 2007 at 19:14:15:
Are you getting any oil in the cooling system? If not, the oil cooler is probably OK.
If the o-rings on the sleeves are leaking, they can be replaced on the cheap by removing the head and pan and then pushing the sleeve and piston out as an assembly. Clean the groove and the mating surface. Install a new o-ring and reassemble. If you remove the piston from the sleeve the old rings will not seat properly so just leave them together.
You said the bottom end was redone so you should be able to get by with six o-rings and a few gaskets.
