Re: Farmall C leaks water
Posted by big Ted on April 04, 2007 at 06:53:44 from (69.216.168.1):
In Reply to: Farmall C leaks water posted by Tom/Idaho on April 04, 2007 at 05:31:17:
yes there are actually two soft plugs on the rear of the motor..just had fix one of mine..just split the tractor..quite easy on these little tractors..compared to the 986 we had apart this winter..
