Re: To Pat H
Posted by Gauger on April 04, 2007 at 08:01:39 from (12.155.240.196):
In Reply to: Re: To Pat H posted by Pat H on April 03, 2007 at 15:29:37:
The H used a 43304DA for retaining both the countershaft and main shaft bearings up until a certain serial number and then on later H and through the SH's the one for the countershaft was changed to a 56520D. The groove dimensions and shaft diameters are still the same in the two shafts so I don't know how the 56520D ring differs. Sadly I didn't keep the old ones. I assume I could still use the 43304DA for both applications.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
