Re: 1066 Hyd. Assist Clutch - Hey Tractor Vet
Posted by Owen Aaland on April 04, 2007 at 09:14:42 from (65.161.86.37):
In Reply to: Re: 1066 Hyd. Assist Clutch - Hey Tractor Vet posted by Michael Sheik on April 04, 2007 at 08:14:07:
After a little more thought on the subject, only
the front one has the threaded hole. The rear
one has a smaller pin sticking out to operate
the safety starter switch.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
