Re: 66 power steering cylinder
Posted by Owen Aaland on April 04, 2007 at 16:26:18 from (65.161.86.37):
In Reply to: 66 power steering cylinder posted by Gp1566 on April 04, 2007 at 10:33:47:
When the ball joint type end is used to replace
the block and pin style, you also need to
replace the cylinder tube. The trunnions are
located closer to the left end of the tube used
with the ball type joint.
