Re: broken rocker arms
Posted by RustyFarmall on April 04, 2007 at 18:41:22 from (66.43.253.62):
In Reply to: broken rocker arms posted by sven on April 04, 2007 at 18:16:26:
When you had the valves ground, did the shop install new valve guides at the same time? If so, those new guides might not have been reamed to the correct size, and when the engine gets good and warmed up, the valve stems will expand and get tight in the guides, causing the valves to stick. Once the engine has cooled down a bit, everything will loosen up and appear to be just fine again.
