Re: Thermostat ....Torque Values
Posted by NDS on April 04, 2007 at 21:04:44 from (64.12.117.8):
In Reply to: Thermostat ....Torque Values posted by Tom Windsor on April 04, 2007 at 20:41:31:
I would run thermostat.
Torque for 3/8 16 bolt Grade 2.. 16 dry 12 wet, Grade 5.. 30 dry 23 wet, Grade 8..45 dry 35 wet. At least that is what chart I checked says.
