Re: Thermostat ....Torque Values
Posted by williamf on April 05, 2007 at 02:27:09 from (66.82.9.62):
In Reply to: Thermostat ....Torque Values posted by Tom Windsor on April 04, 2007 at 20:41:31:
If it runs cold it's more likely that the thermostat needs replacing rather than abandoning.
When I first got my H it never warmed up without covering the radiator; once I replaced the thermostat it warms up to normal operating temperature (160-180) quickly. I'm told that letting them run cold all the time is hard on the engine.
Thermostats, even brand new ones, can be stuck open.
Good luck, Wm
