Re: Farmall A engine
Posted by Janicholson on April 05, 2007 at 19:54:09 from (66.173.50.49):
In Reply to: Farmall A engine posted by Tyler Cohrs on April 05, 2007 at 18:56:05:
Smoke at Idle may be valve guides. If you idle down a hill in high gear, does it smoke even more? If so it could use guides. I like Perfect Circle valve seals. They regulate stem oil consumption and do not require pulling the head to install, and modest in cost and time.
If the cap is held on with the groves on the outside of the neck it is a Pressure system (4-6# cap). If the cap is fastened into grooves on the inside of the neck it is atmospheric. (that cap looks a lot like the gas cap. A water pump can be added with some mods to the drive belts, however the thermosiphon system works very well if the block and radiator are nice and clean. If they are filled with rusty deposits, the pump will only mask the issue. Flush and clean the system first to get a handle on the condition of the deposits.
Good luck, JimN
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
