Re: H carb removal Question
Posted by tom windsor on April 06, 2007 at 10:37:38 from (69.40.55.37):
In Reply to: H carb removal Question posted by City-Boy McCoy on April 06, 2007 at 06:23:11:
Just disconnect the fuel line, the choke rod, and two bolts...then it is off. Now, that is a mouthfull and seems simple enought till you get to the rear nut or bolt. The fuel line, choke, and front bolt are a charm. The bolt in the rear is not. You really need to bend up a cheap wrench in order to get around there...
