Re: (Farmall) A Team Request Update
Posted by Roger Mills on April 06, 2007 at 12:00:56 from (64.122.113.206):
In Reply to: (Farmall) A Team Request Update posted by dunniteowl on April 06, 2007 at 11:32:03:
As Jay said, give er a go. You need to block the radiator with cardboard or ? then run it until a candy thermometer shows coolant above 160 to 170. Run until the oil and the engine sides are up to working temp. That will activate the sealer, then re-torque. I understand that the final torque was upped to 80#. Then do another comp check-if they are coming up run the socks off it under heavy load then cool down and load it again. Do that for several cycles over 5-10 hours of running time and it should come back even more. Good luck.
