Farmall Tractors Discussion Board
Re: radiator F-20
Posted by Farmall Gray on April 29, 1999 at 19:20:03:
In Reply to: radiator F-20 posted by Randy on April 28, 1999 at 18:55:59:
If you have a round tube core, get a rubber tipped
blow gun for on an air hose. Submerge the core in water and blow in to one end of each tube while
holding your finger over the othe end. Don't use more than about 15psi. If you see bubbles, that tube leaks. If you have an oval tube core you will have to make your own tip for the blow gun that fits the oval hole.
Post a Followup
: Re: Re: radiator F-20
