Re: Super A crank Case noise
Posted by banjo on April 06, 2007 at 21:48:23 from (65.67.203.100):
In Reply to: Super A crank Case noise posted by M. Leberman on April 06, 2007 at 21:18:52:
If it sat that long and there was moisture in the tranny it may be part of a bearing rusted off or some teeth on the aluminum oil gear came off.
When you drain the gear oil check for metal peices,bearing cage ,gear teeth.
