Re: my lift wont go down on a 1086 international
Posted by Joe Schmitt on April 07, 2007 at 06:54:54 from (216.222.176.21):
In Reply to: my lift wont go down on a 1086 international posted by 1086 on April 06, 2007 at 18:49:51:
You have got good info from all replys one thing I have seen is the draft sensing arm comming up from the torsion tube will be clamped just a hair too much to the left and the valve control arm comming down from the top will pop past on the right. Looking in from the 3rd link bracket cover you should see if this is the case. By reaching in and moving the top arm against the spring the valve will open and arms will drop. Be sure not to have any implements on it or you could br crushed.
Today's Featured Article - Harry Ferguson - The Man & The Machine Harry Ferguson was christened Henry George but every one called him Harry. Harry was born in a small Irish town called Growell in County Down about 16 miles from Belfast. Harry Ferguson led a varied and colorful childhood causing mischief where ever he could. He showed mechanical aptitude at a very early stage in life and showed no inclination towards ... [Read Article]
