Re: 884 hydraulic problems
Posted by Bernard le mécano on April 07, 2007 at 16:56:49 from (207.134.205.166):
In Reply to: 884 hydraulic problems posted by Tom884 on April 07, 2007 at 14:13:16:
HI Tom, check under the hydrolic filter for a large plug, it have the flo-divider valve in the hole, check if it move freely. If the valve is stuck, no the steering or hydolic work ok. Make sure to replace the spool and spring in the same way. Bernard le mécano Québec Canada
