Re: need IH/FARMALL carb help
Posted by ChadS on April 07, 2007 at 17:38:45 from (65.145.87.160):
In Reply to: need IH/FARMALL carb help posted by bil b va on April 07, 2007 at 12:37:40:
Vacuum leak? Gasket on the metering stem leaking, idle passages plugged and running off the main jet, internal crack in the carb. Seen alot of this happen if it sits and gets some water inside the carbs casting, freezes up and a hairline crack leaks fuel.
