Re: Super A crank Case noise
Posted by M Leberman on April 07, 2007 at 19:28:16 from (71.14.25.143):
In Reply to: Super A crank Case noise posted by M. Leberman on April 06, 2007 at 21:18:52:
Hi guys, ok I lied I could not sit around today and not check so I pulled it out of the barn and into the shop, fired up the floods and the heaters and went to work. Here is what I have found. The sound was indeed coming from the crank case under the gear shift. The sound did not stop when the clutch was engaged and the sound/noise and clicking was proportionate to the speed of the engine. I took off the crank case inspection hatch. At first everything looked ok. All the teeth I could see looked in really good shape. I started turning the hand crank in one inch increments and inspected the teeth. After a while bad news rotated around. Just how bad I need some advice on. On one of the lower sprockets there is are several broken teeth and a 3 inch stretch where the teeth have been broken down to half their height. I have uploaded 3 pics to photobucket which can be seen here http://s101.photobucket.com/albums/m74/mishypurple/Super%20A%20gears/ In one of the cogs just above the broken teeth I found a pretty large metal fragment. The top of a tooth which I removed. Now all the other gears/ sprockets looked in really good shape and so does this one except for the 3 inches or so where the teeth are damaged. I know its not good but just how bad are we talking here? Is the problem being caused by metal debris in the works? Or is it also the broken teeth along with the debris? If I flushed out the crank case with kerosene several times and got all the metal shavings could I possible avoid having to split the case? What do you guys think from the pics. Also I have the reprint of the IH user maintenance Manuel. Its crap. Under crank case bearing it says take it to a IH dealer. It’s a real rubbish check the oil here but don’t do anything else yourself kind of Manuel. Which shop manuals are you guys using? Mike
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
