Re: O. T. The house is on fire.
Posted by Janicholson on April 08, 2007 at 08:19:25 from (66.173.50.137):
In Reply to: O. T. The house is on fire. posted by georgeky on April 08, 2007 at 07:56:51:
Pyrotechnic Easter bunnies!!!
That is a most fortunate alertness on your part, Well done. The thing is you would need that hole to put in fire proofing anyway. Good luck, and better fortune. I just spent the better part of 1800 replacing the Heat-o-later system in my 1938 house. It had rusted through like Tom winsors oil pickup and pan on his H. Seasons greetings JimN
