Re: O. T. The house is on fire.
Posted by Karl Hamson on April 08, 2007 at 09:24:32 from (139.142.98.89):
In Reply to: Re: O. T. The house is on fire. posted by billyiron on April 08, 2007 at 08:10:59:
Living on an island with no gas supply, most folks here use wood heat. I was a volunteer fireman for many years and attended too many chimney fires or wall fires behind the chimney. Make sure chimneys and flues are checked annually and that codes regarding clearances, etc are adhered to. That was a close call. Happy Easter.
Karl
