Re: Update 884 hydraulics problem
Posted by georgeky on April 08, 2007 at 15:28:33 from (152.163.100.197):
In Reply to: Update 884 hydraulics problem posted by Tom884 on April 08, 2007 at 13:40:23:
That could be the problem. If it has had the wrong oil in it sometime there could be brake disk particles stopping up the filter. A guy that use to help me put AW-32 in my 7610 Ford and in 2 or 3 days I had no hydraulcs. I pulled the filter and it was stopped completly up. I drained the oil and replaced it with the right oil and replacing the filter several more times, it has worked ok ever since. Just a thought. Being low on fluid could also be the trouble.
