Farmall Tractors Discussion Board |
Re: Re: Need help with part-numbers, got parts not sure what they go to
Posted by Phil Auten on April 30, 1999 at 05:13:28:
In Reply to: Re: Need help with part-numbers, got parts not sure what they go to posted by John Lenfestey on April 29, 1999 at 08:08:27:
John, You could have an International 330. Does it have the exhaust out the bottom instead of out through the hood? Serial number plate would be located on the clutch housing on the right side as viewed from the seat. Engine serial number is located on the engine block above the distributor. Serial number prefix is probably I330. If it has a cigarette lighter on the dash that is another clue. Should have 5.50x16 front and 11.00x28 rear tires. Phil
Post a Followup
