Re: Case 2150 Paint
Posted by CNKS on April 08, 2007 at 17:41:57 from (204.249.178.32):
In Reply to: Case 2150 Paint posted by Tonti on April 08, 2007 at 15:32:22:
Activator and hardener are the same thing, you probably mean reducer and hardener. Case-IH has both, some dealers don't. The ratio of paint:reducer:hardener is about 4:1:1, but you might have to experiment a little. If your dealer does not have the hardener, acrylic enamel hardener might work. 2150 is an acrylic modified alkyd enamel, that is the old alkyd or synthetic enamel with some acrylic properties, notably UV inhibitors to reduce fading. I have not used it, my numbers are based on what I have read, and my use of acrylic enamel and acrylic urethane. Your results may differ.
