Re: Super C Crank Bearings
Posted by El Toro on April 08, 2007 at 19:23:27 from (152.163.100.197):
In Reply to: Super C Crank Bearings posted by Hartford in Beeton on April 08, 2007 at 16:51:29:
Take that crankshaft to your local auto machine shop and have them measure it. It may need to be polished or ground undersize. They can supply the correct insert bearings too.
Your tractor should have a water pump for circulating the coolant. I don't think using an overbore kit will cause cooling problems provided
your block is thoroughly clean and the radiator isn't plugged. That block area around where the new sleeve seals are installed needs to a good cleaning. Hal
