Re: farmall a tranny replacement
Posted by Janicholson on April 09, 2007 at 10:03:43 from (199.17.6.122):
In Reply to: farmall a tranny replacement posted by wegman in Mn on April 08, 2007 at 19:46:58:
They just seem to look tippy.
If it has the cast wheel on the right, and the steel wheel on the left, they are ballanced enough to do work as well as any tractor. Avoid paralleling hills, go down steep hills, and up modest hills.
As noted in the post below, there can be a hybred made to cure the narrwoness, (and have been made) but I would not go to the trouble of adapting such different animals as an AC with a IH. It would be less than either tractor alone. JimN
