Re: Farmall M with Bucket - Worth the money?
Posted by Chad Franke on April 09, 2007 at 10:08:09 from (65.112.203.194):
In Reply to: Farmall M with Bucket - Worth the money? posted by eryp on April 08, 2007 at 08:56:08:
Needs a new cylinder for the three point, and a bracket built so it's not using the original drawbar to lift. Needs the brackets where the tilt cylinders attach to the buckets redone, way too weak to use as is. Needs some welds redone on the loader. The front bolster needs rebuilt. Leaking front seal on the engine. Put new tires on the rear before you pull a disc, and a new tube on the left front will help with the flat tire.
If you did get it for $2000, not a bad deal, needs some work but will be a good tractor. We looked at it Saturday around 1:30.
