Re: International 140 Transmission/ONE MORE THING
Posted by Hugh MacKay on April 09, 2007 at 15:53:53 from (209.226.247.5):
In Reply to: Re: International 140 Transmission/ONE MORE THING posted by mhalter on April 09, 2007 at 09:34:36:
mhalter: You can probably change the front bearing on the lower shaft, without removing the shaft. The lower shaft and gear that turns the rear end carrier are all one piece. The removal is described as follows After removing the carrier, slide the lower shaft out the back removing gears as you do this.
This book I have is the original IH Blue Ribbon Srevice manual that came with these tractors. There is about 6 pages detailing removal disassembly and assembly of Transmission, rear end and pto. I don't have them scanned but could copy and send these pages to you. Send me an e mail. We can't have a 140 rusting away, not working. I might add there are some very fine settings in putting this back together.
