Re: Super A crank Case noise II
Posted by JayWalt on April 10, 2007 at 09:15:46 from (69.221.13.154):
In Reply to: Super A crank Case noise II posted by M Leberman on April 10, 2007 at 07:56:03:
if u can figure out which gear it is, you could just avoid using that gear. Since its always present, its probably an input or constant mesh gear, and in that event I would really recommend fixing the gear. Flushing it out with kerosene might fix the noise issue if its caused by the broken off pieces binding a bearing or getting into the gears. You can try flushing it out, and if that doesnt work, its gonna really need to be fixed. If the noise is still present, it doesnt matter if its from the gear itself or from a bearing going out due to metal particles in it, the result is still the same. If it comes down to that, then you need to take it apart and make sure to clean all of the bearings thooughly while u have it apart. I would remove each bearing and flushing it thooughly with carb or brake cleaner while slowly spining it. Then out a little bit of lightweight oil in the race and spin it by hand to check it for wear and if there is any detectable roughness when u spin it, then it needs replaced while you have it apart. Even if just flushing it eliminates the problem, you need to find out which gear is causing this and determine if you are willing to risk running it under power and having the gear shred more teeth and do even more damage. On my 300U, the 4th gear has a few half broken teeth. This gear isnt constant mesh and makes no noise when using it, so I'm going to let it be.
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
