Re: Super A crank Case noise II
Posted by Daniel H. on April 10, 2007 at 13:58:48 from (64.151.73.100):
In Reply to: Super A crank Case noise II posted by M Leberman on April 10, 2007 at 07:56:03:
My guess is that it is the oil slinger gear. These were cast aluminum and prone to breakage. You could clean out the transmission, refill with clean oil and run it, as the oil slinger is there for when doing belt pulley or stationary PTO work. An aftermarket gear is around $120.00.
