Re: 806 Hydraulics
Posted by Joe schmitt on April 10, 2007 at 17:14:01 from (216.222.176.21):
In Reply to: Re: 806 Hydraulics posted by Harlen Larson on April 09, 2007 at 18:23:52:
Have you changed the hyd. filter recently? Oil level OK? Does 3pt.lift a load? How much oil is leaking out the back of the valve ? is it just a little spit when you move the lever or is it a pretty good stream? ie the detent actuator unscrewed.Can you feel any detent when you move the levers? Can you hear the relief valve squeal when you try to lift a load? Sorry ,lots of questions but the answers will help pin point problem.
