Re: broken cam gear on H
Posted by r4etired on April 10, 2007 at 18:04:05 from (205.188.116.138):
In Reply to: broken cam gear on H posted by brett harmon on April 10, 2007 at 17:47:34:
I would recommend a 1000lb max.for pressure, that will lift any implement designed for your tractor
