Re: Are belt pulleys interchangable H/M?
Posted by Haas on April 12, 2007 at 08:48:21 from (12.65.66.86):
In Reply to: Are belt pulleys interchangable H/M? posted by Mike CA on April 11, 2007 at 20:33:51:
The pulley gear box assembly is not the same for the H and the M. However, the flange mount on the pulley shaft is the same and the pulleys themselves can be used on either tractor. There are a variety of pulley sizes available and which one to use is determined by the belt speed you want. The H pulley shaft turns faster than the M, therefore, the H pulleys are typically smaller than the M pulleys. Also some pulleys have 8 bolts and some 4 bolts, but the bolt circle is the same so either will bolt up. The larger pulleys are usually 8 bolts.
