Re: Bought A Basket Case
Posted by dhermesc on April 13, 2007 at 06:51:52 from (24.248.193.103):
In Reply to: Bought A Basket Case posted by neblinc on April 13, 2007 at 05:30:18:
If you get desperate I have a good rim from an M (12") with a tire that holds air (not weather checked but well worn) that will fit. I also have a good 13.6 tire that could be mounted. I'm near Manhattan Kansas.
